삼성 아틱 HC-SR04 초음파 거리센서 사용하기
메이커 2018-09-11 (화) 09:23 7년전 5563
https://goo.gl/JVMp9q
아두이노 IDE 사용시
1.    OTG, Debug 케이블 연결 후
2.    VCC – 5V / GND – GND / Trig – GPIO0 / Echo – GPIO1
3.    Putty 접속 후, 터미널에서 /root/watcher 입력
4.    아두이노에서 삼성 아틱의 COM포트 설정
5.    소스코드 업로드
#include <DebugSerial.h>
const int trigPin = 2;
const int echoPin = 3;
// defines variables
long duration;
int distance;
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin, INPUT); // Sets the echoPin as an Input
DebugSerial.begin(115200); // Starts the Dustserial communication
// Clears the trigPin
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
// Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Reads the echoPin, returns the sound wave travel time in microseconds
duration = pulseIn(echoPin, HIGH);
// Calculating the distance
distance= duration*0.034/2;
// Prints the distance on the Serial Monitor
DebugSerial.print("Distance: ");
DebugSerial.println(distance);
6.    Putty로 모니터링
1f7c3ee5d7e718d5cf0b1a77c77892dc_1536645
파이썬 코드
nano hcsr04.py로 파일을 만들고, 다음의 소스코드를 붙여 넣습니다.
 import time
OUTPUT = 1
INPUT = 0
HIGH = 1
LOW = 0
TIMEOUT = 60000
uS = 1e-6
def reg(pin):
    try:
        exp.write(str(pin))
        #exp.close()
    except IOError as e:
def unreg(pin):
    try:
        uexp.write(str(pin))
        uexp.close()
def pinMode(pin, mode):
    try:
        direction.close()
def digitalWrite(pin,value):
    try:
        val.write(str(value))
        val.close()
def digitalRead(pin):
    try:
        value = file.read()
        file.close()
        return int(value)
        #print('READ ERROR')
        return 0
def analogRead(pin):
    print(filePath)
    try:
        file = open(filePath,"rb",0)
        value = file.read()
        file.close()
        return int(value)
        print('Error: %d - %s' %(e.errno, e.strerror))
        return 0
def pulseIn(pin,state,timeout=1000000L):
    #Wait for any previous pulse to stop
    while (digitalRead(pin) == state):
        print(timeout)
        if (timeout == 0):
            print('PULSE TIMEOUT')
            return 0
        #time.sleep(uS)
        timeout -= 1
    #Wait for next pulse to start
    while (digitalRead(pin) != state):
        if (timeout==0):
            return 0
        #time.sleep(uS)
        timeout -= 1
    #Initialize TIMER
    Timer = time.time()
    #Measuring current pulse
        if (timeout==0):
            return 0
        #time.sleep(uS)
        timeout -= 1
    return (time.time() - Timer) * 1000000
#ULTRASONIC SENSOR
trig = 128 # ARTIK 710의 GPIO 0번
echo = 129 # ARTIK 710의 GPIO 1번
reg(trig)
reg(echo)
pinMode(trig,OUTPUT)
pinMode(echo,INPUT)
try:
    while True:
        digitalWrite(trig,LOW)
        time.sleep(20 * uS)
        digitalWrite(trig,HIGH)
        time.sleep(1 * uS)
        duration = pulseIn(echo,HIGH)
        distance = duration/2/29.412
        print('Duration: %d - Distance: %0.2f' %(duration,distance))
        time.sleep(0.5)
except KeyboardInterrupt:
    unreg(trig)
    unreg(echo)
실행하기 위해 python hcsr04.py
