삼성 아틱 조도센서를 이용한 LED 밝기 조정하기
메이커 2018-09-11 (화) 09:23 7년전 5159
https://goo.gl/JVMp9q
아두이노 IDE 사용
1.    OTG, Debug 케이블 연결 후
2.    VCC-5V, GND-GND, SIG-ADC1
3.    Putty 접속 후, 터미널에서 /root/watcher 입력
4.    아두이노에서 삼성 아틱의 COM포트 설정
5.    소스코드 업로드
#include <DebugSerial.h>
int sensorpin = 1;
void setup()
   DebugSerial.begin(115200);
void loop()
   DebugSerial.println(analogRead(sensorpin));
   delay(1000);
6.    Putty로 모니터링
C언어 사용시
 #include <stdio.h>
#include <stdlib.h>
#include <stdbool.h>
#define HIGH            1
#define LOW 0
#define ANALOG_PIN          0 // A0
#define PWM_PIN 0
#define PERIOD 1000000
bool pwmPin(int pin, int period, int duty_cycle, int enable){
    FILE * fd;
    char fName[128];
    if(( fd = fopen("/sys/class/pwm/pwmchip0/export", "w")) == NULL) {
        return false;
    fprintf(fd, "%d\n", pin);
    fclose(fd);
    sprintf(fName, "/sys/class/pwm/pwmchip0/pwm%d/period", pin);
        printf("Error: can't open pin period\n");
        return false;
    fprintf(fd, "%d\n", period);
    fclose(fd);
    sprintf(fName, "/sys/class/pwm/pwmchip0/pwm%d/duty_cycle", pin);
        printf("Error: can't open pin duty_cycle\n");
        return false;
    fprintf(fd, "%d\n", duty_cycle);
    fclose(fd);
    sprintf(fName, "/sys/class/pwm/pwmchip0/pwm%d/enable", pin);
        printf("Error: can't open pin enable\n");
        return false;
    if(enable == HIGH) {
        fprintf(fd, "1\n");
    else {
        fprintf(fd, "0\n");
    fclose(fd);
    return true;
int analogRead(int pin) {
           FILE * fd;
           char fName[64];
           char val[8];
           // open value file
           sprintf(fName, "/sys/devices/12c0000.adc/iio:device0/in_voltage%d_raw", pin);
           if((fd = fopen(fName, "r")) == NULL) {
                       printf("Error: can't open analog voltage value\n");
                       return 0;
           fgets(val, 8, fd);
           fclose(fd);
           return atoi(val);
int Con_duty(int duty) {
           pwmPin(PWM_PIN, PERIOD, duty, 1);
int main(void)
    long SenVal = 0;
    while(1)
        SenVal = analogRead(ANALOG_PIN);
        printf("val : %d\n", SenVal);
                       if (SenVal > 500) Con_duty(100000); // LED ON
                       else if (SenVal <= 500) Con_duty(0); // LED OFF
                       sleep(1);
           return 0;
파이썬 사용시
 from time import sleep
OUTPUT = 'out'
INPUT = 'in'
HIGH = 1
LOW = 0
def export(pin):
    try:
        exp.write(str(pin))
    except IOError as e:
def unexport(pin):
    try:
        uexp.write(str(pin))
        uexp.close()
def pinMode(pin, mode):
    try:
        direction.close()
def digitalWrite(pin,value):
    try:
        val.write(str(value))
        val.close()
def analogRead(pin):
    try:
        file = open(filePath,"rb",0)
        value = file.read()
        file.close()
        return int(value)
        print('Error: %d - %s' %(e.errno, e.strerror))
        return 0
LEDpin = 128
LightSensor = 0
export(LEDpin)
pinMode(LEDpin,OUTPUT)
try:
while True:
raw = analogRead(LightSensor)
volt = raw * 1.8/4095
print("Raw value: %d" %raw)
print("Voltage: %0.2f" %volt)
if raw <= 1024:
digitalWrite(LEDpin, HIGH)
else:
digitalWrite(LEDpin, LOW)
sleep(0.5)
except KeyboardInterrupt:
unexport(LEDpin)
print("Stop!!!")
