삼성 아틱 710S와 조도센서 파이썬 예제 2개
메이커 2018-09-11 (화) 09:23 7년전 4188
파이썬 사용시
https://goo.gl/JVMp9q
1f7c3ee5d7e718d5cf0b1a77c77892dc_1536643
 from time import sleep
OUTPUT = 'out'
INPUT = 'in'
HIGH = 1
LOW = 0
def export(pin):
    try:
        exp.write(str(pin))
    except IOError as e:
def unexport(pin):
    try:
        uexp.write(str(pin))
        uexp.close()
def pinMode(pin, mode):
    try:
        direction.close()
def digitalWrite(pin,value):
    try:
        val.write(str(value))
        val.close()
def analogRead(pin):
    try:
        file = open(filePath,"rb",0)
        value = file.read()
        file.close()
        return int(value)
        print('Error: %d - %s' %(e.errno, e.strerror))
        return 0
LEDpin = 128
LightSensor = 0
export(LEDpin)
pinMode(LEDpin,OUTPUT)
try:
while True:
raw = analogRead(LightSensor)
volt = raw * 1.8/4095
print("Raw value: %d" %raw)
print("Voltage: %0.2f" %volt)
if raw <= 1024:
digitalWrite(LEDpin, HIGH)
else:
digitalWrite(LEDpin, LOW)
sleep(0.5)
except KeyboardInterrupt:
unexport(LEDpin)
print("Stop!!!")
다른 방식의 소스코드 (파이썬)
조도센서 사용하기
2.    하드웨어 연결은 다음과 같습니다.
import time
OUTPUT = 'out'
INPUT = 'in'
HIGH = 1
LOW = 0
def reg(pin):
    try:
        exp.write(str(pin))
        #exp.close()
def unreg(pin):
    try:
        uexp.close()
    try:
