#!/usr/bin/python
import
time
import sys
print
"Toggle a button"
buttonpin
= 30
#export
pin 30 by opening file and writing the pin number to it
pinctl =
open("/sys/class/gpio/export", "wb", 0)
try:
pinctl.write( str(buttonpin))
print "Exported pin",
str(buttonpin)
except:
print "Pin ", str(buttonpin),
" has been exported"
pinctl.close()
#set pin
to be digital input
filename =
'/sys/class/gpio/gpio%d/direction' % buttonpin
pinctldir
= open(filename, "wb", 0)
try:
pinctldir.write("in")
print "Set pin ",
str(buttonpin), " as digital input"
except:
print "Failed to set pin
direction"
pinctldir.close()
def
exit_gpio():
#unexport pin
pinctl =
open("/sys/class/gpio/unexport", "wb", 0)
try:
print "Unexported pin",
str(buttonpin)
except:
print "Pin ",
str(buttonpin), " has been unexported"
pinctl.close()
#pin value
changes when the button is pressed
filename =
'/sys/class/gpio/gpio%d/value' % buttonpin
while
True:
try:
pin = open(filename, "rb",
0)
print pin.read()
time.sleep(1)
pin.close()
except KeyboardInterrupt:
exit_gpio()
sys.exit(0)
