How to Insert a Table of Authorities in WPS Writer: Step-by-Step Guide…
작성자 France 작성일26-01-14 04:19 조회4회 댓글0건관련링크
To add a authorities table in WPS Writer, begin by tagging the source entries you wish to list in your table. Start by choosing the segment in your document that represents a juridical citation, including a law, a rule, or a precedent. Then, open the Citations tab on the interface at the document header. Click on the Mark Citation button. A configuration box will show up, where you can assign the classification of the authority, such as Ruling, Law, or Ordinance. Type the appropriate category, and if required, enter a short citation that will appear in the table. Press Save to commit this entry. Carry out this process for all reference you wish to list in your citation index.
After all citations are labeled, position your pointer at the position in your document where you want the list to show up, generally right after the directory. Navigate to the References tab and hit the Insert Table of Authorities button. A settings window will display with several design parameters. You can pick from predefined styles or adjust the layout by adjusting indentation, gap, and text style. Confirm the appropriate category is enabled if you wish to filter only targeted references of authorities. You may also determine whether to include page references and whether to arrange entries in alphabetical order or by type. Once making your settings, press Create to generate the table.
WPS Document Editor will automatically generate all the labeled authorities into a professionally styled index, showing each legal source along with its folio. In case you later include or remove citations, or revise the phrasing of current ones, you can rebuild the table by context clicking on it and picking Rebuild Index from the right-click menu. This preserves your table is kept correct as your document is modified. Never skip inspect the resulting table for accuracy and wps下载 completeness, particularly if you have made significant edits to your document post-insertion. This technique helps attorneys and jurisprudence learners maintain organized authorities in formal legal documents.
