How to Create a Photo Album in WPS Presentation: Build a Slideshow, De…
작성자 Stan 작성일26-01-14 01:56 조회2회 댓글0건관련링크
Creating a photo album in WPS Presentation is a intuitive and elegant way to display your visual content in a dynamic slide series. Whether you are preparing a family memory book, a travel diary, or a client showcase, WPS Presentation offers user-friendly features to help you organize and display your photos beautifully.
Begin by opening wps office下载 Slides and choosing a blank slide deck or a pre-designed layout matching your style. Once your presentation is open, go to the Insert menu on the top and select Photo Album. This will display a prompt where you can add your images. Click on the Disk button to browse your computer and select the photos you wish to include. You can use the Ctrl modifier to select multiple images or use Shift to select a continuous range. After selecting your photos, click Add to load them into the presentation.
The software will assign each photo its own slide by default, but you can customize the arrangement by choosing how many images appear per slide using the Picture Layout options. You can choose from layouts such as full-screen imagery, two images side by side, or a four-image mosaic.
To add polish of your album, use the Photo Border and Frame tools to include edges, drop shadows, or graphic enhancements. You can also maintain visual harmony to your slides by selecting a design template from the Theme menu, which will standardize the backdrop, typefaces, and design tones across all slides.
If you want to change the sequence, simply go to the Slide Sorter view, where you can drag and drop slides into your custom arrangement. To include text labels to your photos, click on each slide, then use the Add Text feature under the Insert tab to write captions below or beside the image. Change the typography to match your theme.
For a refined outcome, consider adding transitions between slides. Go to the Animation menu, pick a smooth transition like Zoom, and configure the speed so that each slide displays for a natural interval. You can also activate the feature to run slides without manual input if you plan to present the album as a self-running slideshow.
Before finalizing, test your slideshow by clicking the Full Screen icon to ensure everything flows smoothly and all images display correctly. Store your project by clicking Save, then Save a Copy, choosing a location and naming it appropriately. You can also convert it to MP4 if you want to share it on social media or open it on systems lacking WPS.
With these steps, you have built an elegant image presentation that captures your moments in a dynamic and engaging format.
