[임시] Neopixel 160개로 시계 만드는 소스
메카 2016-09-21 (수) 10:27 9년전 8082
// NeoPixel Ring simple sketch (c) 2013 Shae Erisson
// released under the GPLv3 license to match the rest of the AdaFruit NeoPixel library
// Edited by Donghwa Jeong 2016-9-13 for Neopixel Clock with 170 LEDs
#include <Wire.h>
#include "RTClib.h"
#ifdef __AVR__
  #include <avr/power.h>
#endif
RTC_DS1307 rtc;
char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
// Which pin on the Arduino is connected to the NeoPixels?
// On a Trinket or Gemma we suggest changing this to 1
#define PIN            6
// How many NeoPixels are attached to the Arduino?
#define NUMPIXELS      170
// When we setup the NeoPixel library, we tell it how many pixels, and which pin to use to send signals.
// Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest
// example for more information on possible values.
  // This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket
#endif
  // End of trinket special code
  Serial.begin(57600);
  if (! rtc.begin()) {
    Serial.println("Couldn't find RTC");
    while (1);
   if (! rtc.isrunning()) {
    Serial.println("RTC is NOT running!");
    // following line sets the RTC to the date & time this sketch was compiled
     //rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
    // This line sets the RTC with an explicit date & time, for example to set
    // January 21, 2014 at 3am you would call:
     //rtc.adjust(DateTime(2016, 9, 13, 11, 25, 0));
  pixels.begin(); // This initializes the NeoPixel library.
int hour = 9;
int minute = 30;
  DateTime now = rtc.now();
    hour = now.hour();
    minute = now.minute();
//    Serial.print(hour);
//    Serial.print(':');
//    Serial.println(minute);
//12시 30분
//1
     for(int i=12;i<=17;i++){
      pixels.setPixelColor(i, pixels.Color(255,0,0));
      pixels.show();
      for(int i=36;i<=41;i++){
      pixels.show();
//2
      for(int i=(48);i<=77;i++){
      pixels.setPixelColor(i, pixels.Color(255,0,0));  pixels.show();
 pixels.setPixelColor(84,pixels.Color(255,0,0)); pixels.show();
 pixels.setPixelColor(85,pixels.Color(255,0,0)); pixels.show();
//3
     for(int i=92;i<=109;i++){
      for(int i=116;i<=127;i++){
            for(int i=128;i<=145;i++){
      pixels.show();
      for(int i=152;i<=169;i++){
      pixels.show();
delay(5000);
pixels.clear();
for(int i=0;i<170;i++){
      pixels.setPixelColor(i, pixels.Color(0,0,255));
delay(50);
pixels.show();
delay(50);
pixels.show();
      pixels.setPixelColor(i, pixels.Color(0,255,0));
delay(50);
pixels.show();
//     for(int i=12;i<=17;i++){
//      pixels.setPixelColor(i, pixels.Color(255,0,0));
//      pixels.show();
//      for(int i=36;i<=41;i++){
//      pixels.show();
//     delay(1000);
//displayDigit(hour/10,0);
// delay(1000);
// displayDigit(hour%10,42);
// delay(1000);
//   displayDigit(minute/10,86);
//   delay(1000);
//  displayDigit(minute%10,128);
//  delay(1000);
void displayDigit(int num, int pos) // num is number, pos is position
  if(num == 0)
      for(int i=(pos+0);i<=(pos+17);i++){
      pixels.show();
      for(int i=(pos+24);i<=(pos+41);i++){
      pixels.show();
  else if (num == 1)
      for(int i=(pos+12);i<=(pos+17);i++){
      for(int i=(pos+36);i<=(pos+41);i++){
 else if (num == 2)
      for(int i=(pos+6);i<=(pos+35);i++){
//    case 3:
//      for(int i=(pos+6);i<=(pos+23);i++){
//      pixels.setPixelColor(i, pixels.Color(255,0,0));  pixels.show();
//      for(int i=(pos+30);i<=(pos+41);i++){
//    break;
//    case 4:
//      for(int i=(pos+0);i<=(pos+5);i++){
//      for(int i=(pos+12);i<=(pos+23);i++){
//      for(int i=(pos+36);i<=(pos+41);i++){
//    break;
//    case 5:
//      for(int i=(pos+0);i<=(pos+11);i++){
//      for(int i=(pos+18);i<=(pos+23);i++){
//    break;
//    case 6:
//      for(int i=(pos+18);i<=(pos+41);i++){
//    break;
//     case 7:
//      for(int i=(pos+6);i<=(pos+17);i++){
//    break;
//    case 8:
//      for(int i=(pos+0);i<=(pos+41);i++){
//    break;
//    case 9:
//      for(int i=(pos+0);i<=(pos+23);i++){
//    break;
